Winter prep recommendations for Midwest driving?
Maria Original Poster
Maria
Threads:12
Reactions:464
Hey fellow Midwest Taco owners! With winter approaching fast here in Ohio, I'm looking for advice on getting my 2022 Sport ready for the harsh conditions we deal with. This is my first winter with the truck and want to make sure I'm prepared.
I'm mainly concerned about:
  • Tire recommendations for snow/ice
  • Any undercarriage protection worth adding
  • Recovery gear that makes sense for our conditions
I've got the stock Goodyear Wrangler tires but hearing mixed things about how they perform in snow. Should I invest in dedicated winter tires or just upgrade to something like BFGoodrich KO2s that can handle year-round?
Minnesota owner here - definitely go with dedicated winter tires if you can swing it. I run Bridgestone Blizzak DM-V2s from November through March and they're incredible in snow. Night and day difference from all-terrains.
For undercarriage protection, consider getting some kind of coating done before the salt hits. The road treatments here are brutal on frames.
I'm in Michigan and went the KO2 route instead of dedicated winters. They're pretty solid in most conditions we get, though nothing beats true winter tires on ice. The advantage is not having to swap twice a year.
For recovery gear, I always carry:
  • Tow strap and shackles
  • Small folding shovel
  • Bag of sand or kitty litter
  • Emergency kit with blankets/water
Also recommend getting some WeatherTech floor mats - the salt and slush will destroy your interior otherwise.
Post #4
Wisconsin checking in! One thing I learned the hard way - get your truck undercoated ASAP if you haven't already. The salt here will eat through everything. I use Fluid Film every fall.
Also consider upgrading to Bilstein 5100s if you're still on stock suspension. Better control in slippery conditions and you can level the front end a bit. Makes a real difference when plowing through deeper snow.
