⚠️ Trailhunter Onboard Air vs Aftermarket — I Didn’t Expect This Result
SmokyMtnTaco Original Poster
Post #1 (edited Mar 24, 2026 12:59)
Trailhunter
SmokyMtnTaco
Trailhunter
Threads:47
Reactions:13
I finally did a real-world side-by-side test between the 4th Gen Tacoma Trailhunter factory onboard air and a serious aftermarket air system after multiple trail days — and I honestly didn’t expect the outcome.I actually like Toyota’s onboard air for convenience. It’s clean, integrated, and always there. But when you factor in air-up time at the end of a long trail day, the difference becomes a lot more noticeable than I thought.
The results weren’t bad for factory… but once you compare airflow and total time, it changes how you look at onboard air vs aftermarket.
If you own a Trailhunter, air down regularly, or are deciding whether factory onboard air is “enough,” this is worth seeing before you commit either way.
Full video with real timing & setup:
Curious where everyone lands on this:
Factory convenience
or
aftermarket speed
Drop your thoughts below — especially if you’ve run both.
YouTube:
https://www.youtube.com/@SmokyMTNTaco
