Toyota's SEMA 'Snowhunter' Tacoma Concept — Cool Gear, But What Would It Actually Cost to Live With?
Carlos R. Original Poster
Carlos R.
Threads:1
Reactions:453
Saw this on Car and Driver and figured it'd spark some discussion here. Toyota brought out a whole lineup of "Snowhunter" concepts to SEMA this year — Tundra, Tacoma, 4Runner, Land Cruiser, and Sequoia — all done up in white/camo wraps with tracked drive systems instead of tires. CALTY Design (Toyota's design studio in Ann Arbor) led the build, which makes sense given Michigan's lake-effect snow.
The Tacoma version is the one that caught my eye. From the article:
  • Roof rack plus a full-length bed rack with MOLLE panels
  • Awning, extra cargo storage, recovery gear, bed lighting
  • Lift kit using Toyota Genuine Parts/TRD components to clear the tracked undercarriage
  • Rigid auxiliary lighting all around, like the rest of the Snowhunter lineup
Obviously the tracked system itself is never going to be a bolt-on option for normal owners (they didn't even say who actually supplied the tracks — mentioned something about Dominator systems being used up north), but the accessory loadout is the part that's realistic. Full bed rack, awning, rock lights, roof rack — that's all stuff a lot of us already run or are considering.
Got me thinking about real-world tradeoffs though. A loaded rack system plus awning plus lift is a good chunk of extra weight and more stuff bolted to the frame and bed rails. Anyone here running a similar "overland light" setup on a 2nd or 3rd gen want to chime in on what it's actually done to your maintenance routine — tire wear, fuel economy hit, squeaks/rattles, bed rail stress? Curious if the concept truck fantasy matches the daily reality.
I run a full-length bed rack (not MOLLE, just a basic steel setup similar to what CBI Offroad sells) plus a roof rack on my '22, and the honest answer is: it's not free. My mpg dropped noticeably once I added a roof-top tent and rack combo — probably lost close to 2-3 mpg on the highway from wind resistance alone, though I never did a controlled before/after test so take that as a gut feeling not hard data.
The bigger issue nobody warns you about is rattles. Every bolt-on accessory is another thing that can work loose over washboard roads. I've had to re-torque rack bolts twice in two years. Worth it for me, but it's maintenance you don't think about until it's annoying you at 2am on a Moab trail.
Cool concept, but I'll be the skeptic — SEMA builds are basically rolling mood boards. Nothing wrong with that, it's fun to look at, but let's not pretend the Snowhunter lift + tracked axle setup tells us anything about what's coming to dealers. Toyota does this every year with wild show trucks and maybe 5% of it ever becomes an actual accessory catalog item.
That said, the MOLLE bed rack idea is legit useful and I wouldn't be surprised if something like that eventually shows up as a Toyota Genuine accessory given how popular MOLLE panels already are in the aftermarket space.
Post #4
Good thread. I'll add a maintenance angle that doesn't get talked about enough: anything you bolt into the bed (full-length racks especially) means more drilled holes or more clamp pressure on the bed rails, and that's a corrosion point if you're not careful with sealant. I'm in the Smokies area and between humidity and winter road salt, I've seen rust bloom around poorly sealed rack mounting points on a buddy's truck within 2 winters.
If anyone's going the rack + awning + lighting route like the concept, just budget time every fall to pull accessories, check for moisture intrusion, and re-seal if needed. Boring maintenance task but it'll save your bed rails long term.
Post #5
The tracked drive system part is wild to think about for maintenance purposes — those things need way more attention than a tire (tension, track wear, drive sprockets) and I'd guess they're brutal on fuel economy and probably not street legal for daily use anyway. Definitely a snow-specific tool, not a daily driver mod.
On the accessory side though, I added a Prinsu roof rack (same brand mentioned on the 4Runner/Land Cruiser Snowhunter builds) a year ago and it's been solid with zero issues — much lighter than I expected and I haven't noticed a real mpg hit, but I also don't have a cargo box up there most of the time. If you're going to add a Thule box or kayak loadout like the Tundra concept, expect the fuel economy conversation to come up again, lol.
