How often are you actually servicing/replacing armor - maintenance reality check
Maria Original Poster
Maria
Threads:12
Reactions:464
Been running full underbody protection on my 2021 OR for about 2.5 years now - CBI skids, RCI sliders, and ARB front bumper. Starting to see some real-world maintenance patterns that weren't obvious when I first armored up.
What I'm dealing with:
  • Skid plates trap dirt/debris like crazy - had to remove the transmission skid twice last year just to properly clean packed mud that was holding moisture
  • Rock sliders developed hairline cracks at two mounting points after that gnarly section on the Alpine Loop - still functional but clearly stress points
  • Front bumper is solid as a rock but the winch mount bolts needed retorquing after 6 months of trail use
The protection has definitely saved my bacon multiple times, but the maintenance overhead is more than I expected. Anyone else finding that armor creates as many service intervals as it prevents damage? Trying to figure out if I'm being too paranoid about inspection frequency or if this is just the reality of running serious protection.
You're not being paranoid at all - armor maintenance is real and most people don't factor it into the total cost of ownership. I pull my transmission and transfer case skids every oil change now because I learned the hard way that packed debris can actually cause more corrosion than no protection at all.
My maintenance schedule: inspect slider mounting bolts every 3 months, remove skids for cleaning every 6 months or after any serious mud/water crossings. It's a pain but beats replacing drivetrain components. The CBI stuff is built like a tank but even tanks need maintenance.
Hairline cracks in sliders are pretty normal if you're actually using them. I've got C4 Fabrication sliders that developed similar stress cracks after about 18 months of moderate trail use. Had them welded up by a local shop for like $80 and they've been solid for another year since.
The key thing I learned is that functional damage isn't always failure - those cracks are the armor doing its job by absorbing impacts that would otherwise go to your frame. Worth monitoring but not necessarily worth replacing unless they're getting significantly worse.
Post #4
This is exactly why I went with a partial armor setup instead of full coverage. I've got front and transmission skids only, no sliders or rear protection. Yeah, I'm more vulnerable in some scenarios, but the maintenance overhead is way more manageable.
I think there's a sweet spot where you protect the most expensive/critical components without creating a maintenance nightmare. My setup takes maybe 30 minutes to remove both skids for cleaning, and I can actually see what's going on under there during regular maintenance. Sometimes less is more, especially if you're not doing extreme rock crawling every weekend.
